The DeeMax wheels arrived. What color rims and hubs should you get? Yeller!
These guys are in stock at Jenson USA and they price matched down to $600.00 for the set. The look and finish are fabulous (built by French guys (unless they have outsourcing also)). These are 05 DeeMax with 28 straight-pull spokes. My CrossMax XL's have 24 spokes. The front wheel is either a 9mm or 20mm, adapter for both included. The rear has it's own axle and nuts.
The first picture is the wheel set with all the adapters, the bearing adjustment tool and the spoke wrench. The second pict shows detail of the front home, the next of the rear hub, the fourth shows the front hub without any adapters and the fifth shows the rear axle.
So far so good. As per my post on the Conti Diesel 2.5, I have had some issues with tires.
Rick
Rick
