With the influx of available options, our bicycle collections of current times often teeter between conscious bicycle enthusiast and irrational two-wheeled hoarder, but no matter how packed your garage is with bikes, organization is key. Bikes can be an awkward thing to store, but some thoughtful devices can help to create order in your bike storage space.
Related: The Best Bike Stands for Home Mechanics
Like many things these days, there is an endless list of options and ways to store your bikes at home. These can be broken down into a variety of categories from simple hook solutions to floor stands and wall stands. Deciding on a system that will work well for your needs while complementing your space can take some research.
Related: The Best Bike Tools and Tool Kits for Home Mechanics
Why type of bike storage is right for you?
When choosing a storage system for your space, take the time to understand how much space you have to work with and what type of space it is. Is it floor space or wall space? Do you have room to hang bikes from a ceiling or rafter? Next, how many bikes do you need to store and how accessible would you like them to be?
Most options for bike storage will fall into one of the below categories:
Bike storage
The Hornit Clug is known for it's small, simple design.​
Wall mounts: These racks mount to existing wall studs in your space and often will hang bikes parallel to your wall. Bike attachment points for these racks include hanging by front or rear wheel, hanging by the bike's frame, or even just by the saddle or seatpost of the bike.
Bike storage
Vertical Floor Racks: These racks offer vertical bike storage and can usually accommodate more than one bike on a single rack. The can either be wall mounted, freestanding, or use an extender type support system. These racks offer easy bike access, keep the bikes off the floor, and also give a space a more bike-centric aesthetic.
Bike storage
Floor Display stands: If you have the floor space, these stands are a simple bike solution for keeping your two-wheeled rigs upright and accessible. These stands can either support the bike by its tires or by the crank spindle. These are the most versatile support system in the bunch as they can easily be moved around your space depending on your needs.
No matter what you choose to help organize your bikes, some key specifics about the bikes you're hoping to store will save you a lot of headaches. What type of bike is it? How heavy is it? Can you hang the bike by its frame? How wide are the tires? Do you have hollow spindle cranks? All of the racks and stands below attach to the bike at different points, so take the time and understand your needs before pulling the trigger.
The Best Bike Storage Options
Feedback Sports Velo Hinge
Feedback Sports offers a great line of bike storage options, for $27 the Velo Hinge offers a simple yet effective solution for hanging your bike vertically on any wall. A plastic-covered hook folds out from the wall plate to accommodate your front wheel, your front tire rests on the plate while the whole thing hinges perpendicularly as far left or right as your handlebars will allow. The bikes then have the ability to rest more flat on the wall depending on your bar width. We like the simplicity and versatility of the Velo Hinge along with it's affordability. Hinge design allows bike to swing left or right and hook folds away when not in use.
Pros:
  • Simple wall mount
  • Easy to hang and remove bike
Cons:
  • Requires screwing into wall studs.
  • 50lbs load capacity
  • Can't accommodate larger tires but longer hook can be purchased
Price: $27.99
Buy Now
Hornit Clug
Bike storage
Bike storage
As one of the simplest bike storage designs in our roundup, the Clug is not only sleek but is surprisingly functional for how minimalist it is. The Clug won a Eurobike award for the smallest bike rack and can work to store bikes both vertically on the wall or horizontally on the floor. Designed around specific tire widths and constructed from flexible plastic, the Clug clamps tightly around the bike's tire. Sizes of the Clug inlcude: Roadie 23-32mm tire width, Hybrid 33-42mm, MTB XL 58-69mm, and XXL Plus 70-81mm
Pros:
  • Super simple design
  • Small space needed for install
  • Almost invisible when not in use
Cons:
  • Bike weight must rest on floor
  • Won't work if tire is flat
  • Tire width specific
Price: $25
Buy Now
Feedback Sports Velo Wall Post
Bike storage
If you're looking for a simple hanging bike storage system to stash your daily driver on, the Velo Wall Post is a great choice for easy access. With a simple fold-out post design, the bike is supported by hanging it from the saddle. Sometimes the most convenient bike storage solutions are also the most simple. Use it to hang your bike, spare wheels, and tires, your rain-soaked kit after a long ride, or whatever sporting goods storage needs you can dream up. When not in use, the Wall Post folds up and out of the way.
Pros:
  • Bike remains easily accessible
  • Can hang other items
  • Fits any and all bikes
Cons:
  • Not the most stable storage
Price: $33.99
Buy Now
Impresa Heavy Duty Bike Hooks
Known as one of the simplest ways to organize your bike-laden garage, heavy-duty bike hooks can't be left out of this list. As I dial in my own garage, I'm happy to purchase a few packs of these to hang up the 10 bikes in my garage to quickly create more floor and shop space. Simply drill a pilot hole into a ceiling beam or wall stud and hang your bike by either its front or rear wheel or add a second hook and hang the bike completely. These hooks are available in a variety of sizes from a variety of manufacturers.
Pros:
  • Cost
  • Simplicity
  • Easy to install and hang numerous bikes
Cons:
  • Must drill into wall and studs
  • Not the most visually appealing option
Price: $16.99 for a pack of 4
Buy Now
Feedback Sports Rakk Storage and Display Stand
Bike storage
Simply roll your front or rear wheel into the tray and the spring-loaded arm does the rest, resulting in a sturdy way to store your bike without having to attach hooks to your wall. You've spent too much of your hard-earned dollars on your bike to just go leaning it against the garage wall. The Rakk stand from Feedback keeps your bike propped up and ready to go for your next ride. It uses a spring-loaded arm easily holds the front or rear wheel by the tire without the risk of scratching rims. Its modular design supports connecting multiple RAKKs together. Specs include: holds 20 mm road tires; up to 2.4"; wide mtb tires In size 20"; to 29"; wheel. Base footprint 13.5"; x 16"; (343 mm x 406 mm), folded height 3.2"; (81 mm), weight 5.9 lbs. (2.7 kg).
Pros:
  • Floor mount
  • Clean, simple, and accessible
  • Super durable and easy to use
Cons:
  • Won't accommodate wider tires
  • Bikes remain on floor
Price: $42.99
Buy Now
Topeak Flash Stand MX
Bike storage
The Topeak Flashstand MX is designed to fit into the hollow spindle of your bicycle's crank and hold up your bike for washing, display, storage, and maintenance. In addition to being a useful bike storage stand, lifting the rear wheel off the ground makes it easy to lube your chain or make shifting adjustments anytime. When the Flashstand isn't in use, it quickly folds down for easy storage. It's constructed with Aluminum, engineering-grade plastic, and steel. Holds bikes up to 39.7 lbs.
Pros:
  • Simple effective design
  • Easy to perform maintenance with one stand
Cons:
  • Must have hollow spindle cranks
  • Less than 40lbs load capacity
  • Not cheap
Price: $69.99
Buy Now
Topeak B2 Bike Stand
Bike storage
Topeak's B2 bike stand is constructed using lightweight aluminum tubing with quick-release locking mechanism and mounts anywhere without drilling holes into your ceiling or floors. Using an extendable tube with a quick-release mechanism, this stand pushes against floor and ceiling to provide a stable, horizontal storage option for your bikes. The aluminum tube extends up to a height of 10' 7.8'' (320cm) and comes with two bike mounts that adjust quickly and securely, and can adjust 30° from horizontal.
Pros:
  • Bikes remain easily accessible
  • No screw holes
Cons:
  • Bikes hang from frame
  • Not great for heavy bikes
  • Won't work if you have high ceilings
Price: $179.99
Buy Now
Thule Bike Stacker
Bike storage
The Thule Bike Stacker is a free standing storage bike rack for your home, apartment or even your garage. Bike hanger arms adjust independently to any height, up and down the length of the rack while the bikes are supported by V-Shaped soft rubber bike holders that fully cushion and protect each bicycle frame. The Thule Bike Stacker can be put anywhere with a level floor, making it an easy storage solution, not to mention, there is no better decor than having your bikes hanging in your swanky apartment.
Pros:
  • Freestanding
  • Great addition to home decor
Cons:
  • Not a cheap storage solution
  • More substantial than other options
Price: $179.99
Buy Now
Delta Cycle Rugged Gravity Rack
Bike storage
Using a simple gravity system, the Delta Rugged gravity rack simply leans against your chosen wall. Once the bikes are mounted on the rack the weight helps to keep the stand firmly against wall and ground. Constructed using powder-coated steel tubing and features independently adjustable arms that accommodate most frame sizes and styles. Wall and floor protection comes from rubber bumpers on feet and upper supports. Total maximum load 100 lbs.
Pros:
  • No drilling or installation
  • Simple, effective design
  • Reasonable price
Cons:
  • Not super stable
Price: $109.99
Buy Now
Pro Bike Tool Wall Mount
Simply find a wall stud and mark your drill points to install this cradling wall mounted storage rack. Free-up your floor space and keep your garage or indoor space tidy by getting your bikes up on the wall. This simple wall hanging solution to bike storage is great for apartments, homes, garages, and sheds. This storage system fits most bike types: road, cyclocross, hybrid and some MTB depending on frame/tubing shape. Can hold bikes up to 22kg / 48.5 lbs weight load. One thing to note is that it is not suitable for bicycles with wide handlebars (31 inches / 78 cm), long wheelbase, or fat bikes.
Pros:
  • Easy install
  • Easy to access bikes
  • Bikes look clean when in storage mode
Cons:
  • Bikes hang from the frame
  • Won't work for all types of bikes
Price: $44.99
Buy Now
Mtbr is committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
