1 - 6 of 6 Posts
A fork isn't a racing engine, just ride the piss out of it for a while and it will break in. I would set it up so that you are using full travel on your break-in ride and then adjust the pressure later to get the feel you are looking for.
Yup, just set it up so you like it....
then ride the piss out of it. After about 30 to 50 miles do an oil change and you've got it. Just don't forget to do the oil change! You'll be amazed at how the forks performance will improve after the break in and first oil change. Like JustMtn said, " it ain't a racing engine". Jut ride it, it'll break in all on it's own.
Good Dirt
carpe mañana
Setting it up a bit soft for your weight will result it more stroke used for given bumps. It will speed up the break in period. Fast and rough, as in jittery, descents will help too. The downside is that the fork will behave like an udersrung fork, so if you wanna ride hard, then set it up like you would a broken in fork. Time is on your side, the more you ride it, the better it will feel. And yeah, don't forget an oil change at about a 25 hour mark and another at about 50. It will be like a warm stick of butter after that.
_MK
1 - 6 of 6 Posts
