1 - 6 of 6 Posts
What brands are you guys running. Just got the new wheels built and now I'm having tension issues... Any help would be appreciated. BTW it's for an 08 p1.
Discussion Starter · #3 ·
The drive slide slips every now and then. No matter how tight it seldomly slides up (toward crank), but never backwards, around 2-3mm... enough to notice the slack. I don't overtighten or undertighten the chain ever
Make sure you get the right size for your axle. If it's too big it doesn't help any.
I use the Redline ones from Dan's Comp. I had to cut and file it a bit to fit the drop out on my mob but they work perfect and are nice and light. I had some Haro ones and they weighed a ton.
Dirt cheap alternative is a lock washer with external teeth. The teeth bite into the metal of the dropout as the bolt is tightened. Literally, a few pennies at the hardware store. Go with stainless steel to prevent rusting.
1 - 6 of 6 Posts
