I have a question about how to approach an obstacle. I love reading responses to posts like this because in the past it has helped me learn - hearing other people's ideas about riding techniques is valuable. Hopefully this will help others as well.
Situation: There is a long concrete beam/pillar that is lying down on its side, and I want to get on top of it. It is square shaped, with the sides being between a foot an a foot and a half tall, and it is about 25 ft long. I thought it would be fun to ride up on it, get to the other end, and drop off. Essentially, I want to climb up an 18" obstacle.
Problem: How to get the back tire up. I can get the front wheel up with no problem. However, there is not enough clearance under the big chainring/BB for the back tire to contact the obstacle and even if there was, I don't think it would really help because it's a vertical face high enough that you can't really "ride up" it. I try to pop up the back tire so that the chainring clears and the back tire contacts it, but I can't seem to get enough air under the back tire to get far enough up the vertical edge that I can pedal up. Part of the problem is that at that point, (1) my weight is shifted slightly back from lifting the front tire up, giving me less leverage and (2), the bike is up at a 25-30 degree angle, again giving me less leverage.
I have been practicing riding up progressively bigger curbs/obstacles and trying to learn how to pop the rear tire up without much/any contact with the obstacle, and I have progressed, which is helping, but that's only part of the problem. I also need to be able to shift my weight forward once my front wheel has cleared the edge so that I can help the back end up, and I'm having trouble with this.
So, the questions that I pose to you are this: Do I have the right idea as far as how to approach the obstacle? Can you tell me how you would approach an obstacle similar to this?
I think the description is clear enough, but if not I can take pictures tomorrow and post them. Thanks so much, and let the insightful discussion begin!
-B
-B
