Hey all!
I have a 2012 Tallboy Carbon with SRAM XX group set. I have kept it stock, so to this point if something broke or wore out I replaced it with the original.
My rear Derailleur brake (only 2nd time in 7 years) and I am having trouble finding a replacement XX. I have found some on ebay…
My question is do I have any other options besides:
1) finding a XX on ebay or
2) replacing the entire groupset.
If I replaced the groupset I would go XTR.
My full bike spec is below. Thanks for any advice.
FRAME: Santa Cruz Tallboy Carbon with selected components from XX package Matte Carbon/Red Medium
Front Suspension Fork: FOX 32 FLOAT 29 120 FIT RLC Fork 15QR 1.5 Taper
Brake: Avid XX Disc Brake Set 160F 160R
Cassettes: SRAM XX Cassette 11/36
Chain Guide: None
Chains: SRAM PC-1091 Chain
Bottom Bracket: SRAM GXP/BlackBox Ceramic Bottom Bracket 68 English
Cranks: Truvativ XX Crankset - 166 Q-Factor 175mm 39/26
Front Derailleurs: SRAM XX High Clamp Front Derailleur Top Pull 34.9mm
Grips: WTB Dual Compound Grip
Handlebars: Easton EA70 Monkeybar Low
Headset: Chris King InSet Mixed Tapered Headset w/ GripLock Black
Pedals: None
Rear Derailleurs: SRAM XX Rear Derailleur Medium
Rear Shock: 2012 FOX FLOAT RP23 Adaptive Logic w/Kashima Rear Shock
Saddles: Selle Italia SL Kit Carbonio Saddle Black
Seatpost: Easton EA70 Zero Setback Seatpost 400mm 30.9mm
Shifter: SRAM XX Trigger Shifter Set
Stems: Easton EA70 Stem 100mm
Tires - Front: Schwalbe Rocket Ron Performance 29 Tire 2.25
Tires - Rear: Schwalbe Rocket Ron Performance 29 Tire 2.25
Tubes: Q-Tubes 29" x 1.9-2.3" 32mm PV Tubes
Wheels: Easton EA70XC Disc Wheelset Black - 29" - 2011 Rear Quick Release 15mm
Sent from my SM-N960U using Tapatalk
Chain Guide: None
Pedals: None
