For what it is worth, nothing is dripping out of mine.
Thanks Bonk, I'll try that. I had quite a bit of drippage over the last few rides. I could see it on my tires and such. Anyway to determine how much oil I lost or if I need more?bonkey said:pull the adjuster knob off with a 1.5mm allen and make sure the black o-ring and 10mm bolt are cinched up. Better yet, pull it off and then put it back on.
I find that many foxes do this and it's no big deal as long as you don't lose a lot of oil.
Redmon. Hard to tell on a fox how much oil you've lost, because they rely solely on volume measurements (in cubic centimeters). If they used both volume and/or oil height, then you'd be able to tell how much to add.Redmon said:Thanks Bonk, I'll try that. I had quite a bit of drippage over the last few rides. I could see it on my tires and such. Anyway to determine how much oil I lost or if I need more?
Shawn
