> Our F80X/F100X Terralogic Forks received a new
bushing for increased durability and reduced friction.
> The FLOAT, FRLT and Vanilla™ families of forks all
have the new Slim Damper Cartridge for reduced weight
and even greater damping control.
> Improved low speed compression range on all RLC models.
Adjust your low speed compression so you can quickly tune
your Fork for any terrain and riding style by simply
turning the blue adjuster.
> New Aluminum damper and spring shafts save weight on
all models.
> New Seal Head Bushing reduces friction and increases
durability on All models.
> FLOAT, TALAS and Vanilla jump to 5 inches/130mm
of travel.
> TALAS has a new primary air seal for less friction.
> Modified Air Spring Curve on FLOAT, F Series, and
TALAS for improved bottoming resistance.
> 8" Rotor compatibility for All models.
> Refined oil and dust wiper seals on all models for less
maintenance and improved sliding performance.
