Hi all,
i'm hesitating between the TALAS 36 and the FLOAT 36 (both 2007 models). i had a test ride in the past on the TALAS 36 of 2005 and didn't like its small bumps sensitivity. i understand Fox has improved it somehow on 2007 but i wonder wheather it can be compared to the plushnes feeling of the FLOAT. The problem is i'm not sure about using a 6.3 fixed travel fork on my Enduro (2006) cause i also like steep technical climbs. does anyone has experience with both? and another question, is it worthwhile getting the RC2 model or is the R good enough? personally i don't believe i'll use the compression adjustments after the initial setup.
