suspension gurus, i need your help once more... i've finally done my oil change on my 2010 32 talas fit rlc with no problems whatsoever. until... i came on to my last screw... the lock nut on the bottom right leg of the fork (where the rebound adjuster is) does not want to screw back on. it will turn at about 2 turns and then the whole shaft turns with it. i tried pulling it apart again and tried it on without the lowers and still the same not unless i hold down the shaft. is there a way to remedy this when the lowers are installed already? i need a way to hold on to the shaft so that it will not turn so that i can tighten up the lock nut. hope someone can help me on this...
