1 - 10 of 10 Posts
This place needs an enema
rryyddeerr said:
Anybody know the ERD of the Bontrager Mustang disc rim and how to set that up in the DT spoke calc?
I use 600 erd for that rim. I've built ~50 of them the last few months and it has been spot-on on every one.
Just use the numbers that the DT calc spits out--should work fine. You *can* adjust +1mm and -1mm to compensate for the OSB if you'd like, but it's not necessary.
MC
The offset calulation only changes the results by +/- 0.2mm.
When doing the calulation for the wheelset that I want to build. Changing the ERD on the Bontrager Disc OBS 700c from 596 to 600 the spoke length change is by a full 2mm.
1 - 10 of 10 Posts
