Do not rotate them. You want to keep your best tire on the front. If you are using the same tire f & r, as you are, when the rear tire wears out you can move the front to the rear and put a new tire on the front.S-Works said:anyone switching front to rear, and rear to front to even out the wear of your tires? I 'm running the 2.1 Weirwolfs on front and back, and wondering if I should switch them.
TIA
That answers my question!shiggy©®™ said:Do not rotate them. You want to keep your best tire on the front. If you are using the same tire f & r, as you are, when the rear tire wears out you can move the front to the rear and put a new tire on the front.
