1 - 13 of 13 Posts
Can anyone tell me what is needed to switch from an 8 speed to a 9? I have a few things so far, X.0 gripshift set, a SRAM pg-970 11-34 cassette, SRAM pc 99 hollowpin 9 speed chain, SRAM X-gen 9-speed 44-32-22 front derailleur, and flak jacket cables for front and rear derailleur. I think i only need a rear derailleur. I'm planing on getting some Race face cranks but not sure if i need them. thx Rod
Mantis, Paramount, Campy
You've Got Too Much Already
The only thing you need is shifters, cassette and chain
No need for different derailleurs or chainrings(crankset)
Cranks Are Cranks
Or should I say chainrings 'cause that's what's important.
Basically any chainring will work fine with any system. 9spd rings play nice with 5,6,7,8,9,10 speed chains 6/7spd chainrings also play well with 5,6,7,8,9,10 speed chains.
I road race sometimes on chainrings that were make in the early 80's and they shift fine with my current 10spd rear end and chain.
Moral of the story: Chainring width has changed very little in the last 30 years. Calling current chainrings 9spd is just marketing.
I Love my Rize
Many Cons
rodman said:
oooo ok, are there any cons changing to a 9 speed ?
9 speed much finickier :rolleyes: , loses tune easier, VERY AFFECTED BY MUD AND BAD CONDITIONS :madman: , break more chains :madmax: , more expensive parts :eekster: , has a gear that you don't need :skep: .
8 speed = better shifting in ANY condition :yesnod: , cheaper parts :D , will hold tune WAY LONGER, lighter as you have 1 less cog (usually the heaviest one too) just plain old better performance (will basicly shift great submerged in mud) There is only 1 plus side to 9 speed and that is the manufacturers are trying to jam them down our throats :incazzato: so they make a gazzilion high end parts for them but their still is very high end parts for 8 speed still (X9 gripshifters and Sram pg850 cassettes and pc 58 and 68 chains) Will never go to 9 speed as long as Sram keeps up the good work. All they need is a 8 speed X9 trigger to make it complete and plus you can still get great xt and xtr 8 speed cassettes. The XO rear derailleur and X9 8 speed gripshift are the BEST setup you could ever use. :thumbsup:
1 - 13 of 13 Posts
