How fast are you usually going before you start coasting? Or, phrased another way, what's the top speed at which you will usually pedal? How fast do you want to be able to sprint on the flats?How much of a difference will I notice. I use this bike as a gravel-grinder/road hero and I'm wondering how much downhill performance will suffer?
Usually about 25-30mph.How fast are you usually going before you start coasting? Or, phrased another way, what's the top speed at which you will usually pedal? How fast do you want to be able to sprint on the flats?
For me, gearing is never really a question for downhills, since I'm coasting. Gearing IS a question on the flats, though.
That's not super noticeable. Thanks10%, 6% and 0%, respectively.
I had to be careful there that my spell checker didn't auto correct to "respectfully" by mistake.
Not often, but sometimes on the downhill.You can use this site:
Bicycle Gear Calculator
to compare the two.
Are you running in your current highest gear a lot? Spinning it out?
What size are your wheels and tires? I use 29 x 2.3" and don't spin out till about 40mph with a 34t chainring, I also use my mtb as a road/gravel grinder frequently. Unless you have skinny tires and 26" wheels I think you'd be more than fine with a 40t ring.How much of a difference will I notice. I use this bike as a gravel-grinder/road hero and I'm wondering how much downhill performance will suffer?
It's a 29er. 11-34 9-Speed CassetteWhat size are your wheels and tires? I use 29 x 2.3" and don't spin out till about 40mph with a 34t chainring, I also use my mtb as a road/gravel grinder frequently. Unless you have skinny tires and 26" wheels I think you'd be more than fine with a 40t ring.
Shimano doesn't make a compatible chainring of that size anymore.Why do you want to change gearing in the first place?
Sent from my SM-G930V using Tapatalk
