Hi all,
I've taken a read of the Switch solutions thread (http://forums.mtbr.com/showthread.php?p=4084720) but I remain a little confused. rockymtnway (http://forums.mtbr.com/showpost.php?p=4099023&postcount=6) had the same idea as me but I couldn't find any follow-up.
Here is what I'm looking to do:
I'd like a two or three position push button switch so I could have High / Medium / Low / Off OR High / Low / Off. High would be set at 800ma.
I'll be running 2 x Cree XR-E R2 (WG) emitters in series. Battery will be a 7.4V 2400mah Li-Ion.
Switches
Looking at using this switch (http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=522PB-ND) or this? (http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=528PB-ND). I'd also consider a toggle type switch but I'd prefer to try and keep everything somewhat waterproof.
Driver
Looking at using this driver (http://www.dealextreme.com/details.dx/sku.3256). However, I'm not sure if I can accomplish what I need with this driver. I realize the 3023 could probably do it but I'm trying to top it out at 800ma.
Can anyone give me hints or direct me to a wiring diagram of how to wire this up? I'm sure I'll need some resistors in there somewhere but I'm not too knowledgeable in this area yet.
Thanks in advance for any suggestions!
Switches
Driver
