I'm on my 2nd SI. First one lasted 3 years, but slowly wore off the coatings so I replaced it recently through my LBS. This is the first time I've done the regular grease service on this SI. Right port accepted the grease as usual. Left port 95% of the grease spits out of the sides of the port. I'm expending so much waste to get grease to go into that port to make some seep out the top of the SI. The ports on my previous SI accepted grease normally. I'm using Yeti's grease & gun (I have a std grease gun as well that I tried and it made no difference). I also tried removing the port and putting grease in directly but that didn't make any difference.
Any suggestions/tricks, or similar problem??
