1 - 7 of 7 Posts
Discussion Starter #1
I have a SB150 and notice the switch infinity translational pivot has much more friction than the rotational pivots. This will bring noticeable friction and damping to the entire rear suspension and I feel the shock's rebound is a little sluggish. Does anyone have any ideas about it and is it necessary to add some rebound to compensate for that effect?
Is it properly greased and cleaned and bearings in good working order?
Sent from my GM1915 using Tapatalk
I would confirm the above.. I've owned mone since 2019 first year release and can't feel what you describe that would cause me to adjust my suspension settings.
Discussion Starter #5
When I compress the saddle the rear end feels fine, but moving the link by hand is not such easy...
Sounds normal to me if everything above is in good working order.
1 - 7 of 7 Posts
