Hello All,
I just installed a set of XR rockers( thanks to MightySchmoePong) on my '04 Burner. I was setting up the sag when I discovered that my Swinger 3 Way was only 6.250" eye to eye and that the shaft was only 1.250" exposed. I played around with the SPV pressure and found that it affects the eye to eye length if the SPV and Air spring pressure are too close. I was running 120psi SPV and 130psi in the air chamber with the original set up. I am now running 90psi in the SPV chamber and 170 in the air spring with the new XR Rockers. I am still only getting 6-3/8" eye to eye and 1-5/16" exposed shaft. Is this normal for a 3 Way? I am running 80psi in my Talas at 120mm travel stting. Does this sound right for 160lb rider? I am ordering an RP23 next week to replace the Swinger. Any information on set-up would be very cool!
