Soupboy said:
Gotta disagree with you. The IMVs I've seen are locked-out until something hits to release it - a la the Brain on the Epic.
This is decidely different than a platform that typically allows some amount of travel but with enhanced resistance to rider/pedaling inputs.
Call it semantics but an RP3 - even PUSHed like mine - is closer to "fully active" than an IMV or Brain unless you just turn off their guts altogether. I can adjust the compression rate on my Fluid to simulate the feel of my RP3 in any setting.
Well, for me there are 2 different factors.
1 is the ability to stay closed whatever force you put on the shock if ridden on flat ground. This is the special category for brain and terralogic technology. Imv does not provide that.
2 is the fact that the shock is fully locked out or not in "locked" position. For example it is not the same on an epic (fully locked out) vs enduro with brain (stiff but not lock out).
I do not own an rp3 shock, but i know that the spv stuff is fully lock out until a hit comes.
If this is the case on an imv fork, it is possible to find the according rear shock, even before WB release their imv shock !
