1 - 1 of 1 Posts
I like the thrushaft technology. Easy to maintain with probably longer intervals. IFP isn't in function while the shock is in compression. So there is as they say less stickton.
Tinkering: about cost and function.
Will a Fox Performance Float EVOL, RE:aktiv met Thru Shaft 3-position shock give a significant better performance as a Fox Performance Float EVOL, RE:aktiv 3-position shock?
The thrushaft is standard mounted in a carbon F EX 2021 frame.
Does it fit in a aluminium F EX 2021?
1 - 1 of 1 Posts
