1 - 4 of 4 Posts
Say Car Ramrod!!
i have a dhx and have experienced the mid stroke travel blow thru many have described. its not as bad as i was expecting. however i was wondering if anyone has put a lower volume air can on it to combat this and what they have found out about the ride. if you have experience with this please post up your thoughts.
Slow Patrol
I swapped the air can on mine. The bike is a '07 Kona Coiler, 2.7 leverage ratio and I am larger than average at 216lbs.
The change really helped. The coiler is fairly linear is shock rate, especially in the forward link position. Ultimately I moved to a DHX Coil and I am much happier.
1 - 4 of 4 Posts
