Hello how come full suspension bikes have 10mm less travel in the rear usually? For example 140mm fork 130mm rear travel. It seems that way for every bike. There must be a reason, right?
That's true, bur the reason is different. The rear travel is vertical travel, that's how all the manufacterers measure it. On the front you would have 140mm of vertical travel if the steering axis was at 90° but it isn't. If you do the math 140mm fork on 65° HTA gives you roughly 128mm ot vertical travel. On a slacker bike I would go for +20mm in the fork to maintain the same balance.Bottom line - slightly less travel rear compared to front makes the bike feel a bit more balanced.
Now THAT I understand!!party in the front. business in the back.
Well, you learn something every day.That's true, bur the reason is different. The rear travel is vertical travel, that's how all the manufacterers measure it. On the front you would have 140mm of vertical travel if the steering axis was at 90° but it isn't. If you do the math 140mm fork on 65° HTA gives you roughly 128mm ot vertical travel. On a slacker bike I would go for +20mm in the fork to maintain the same balance.
On some downhill bikes there is more travel rear than front. My 2017 Jedi has 230mm rear. I believe v10s were 240mm rear, both with 203mm in the front.Not all bikes are built like this. Mine has 180/180
Sent from my moto g 5G using Tapatalk
ok so I don’t do maths so good.What ifyou were running 160mm front travel with a 65* HA. What’s the formula?That's true, bur the reason is different. The rear travel is vertical travel, that's how all the manufacterers measure it. On the front you would have 140mm of vertical travel if the steering axis was at 90° but it isn't. If you do the math 140mm fork on 65° HTA gives you roughly 128mm ot vertical travel. On a slacker bike I would go for +20mm in the fork to maintain the same balance.
Check out the picture by clicked.ok so I don’t do maths so good.What ifyou were running 160mm front travel with a 65* HA. What’s the formula?
For those of us that don’t like math, 90% of front travel is a good approximation for typical trail bike HA.ok so I don’t do maths so good.What ifyou were running 160mm front travel with a 65* HA. What’s the formula?
