Steve from JH said:
Your second set of hypothetical examples is better.
My first example wasn't intended to be an accurate account of what happened. It was intended to be a little bit of truth and a little bit of humor. However, I did choose that particular example for a reason. It is an example where a pivot location was changed for a reason other than suspension performance. That change also moved the location of the IC. If DT was a staunch advocate of ICT, wouldn't the location of the IC take precedence over a bit of drivetrain noise?
Steve from JH said:
I think Turner does believe the ICT setup is better. He just would probably explain it in different terms. He doesn't seem to like to get too much into theory anyway, does he?
When you say ICT setup, are you talking about ICT theory, or the configuration of the linkage that results? I think based on his recent designs, it's pretty obvious that the latter is true. The former is debatable, but since he's not saying, we will probably never know. Besides, there are probably some real marketing advantages to be gained from licensing ICT.
Steve from JH said:
There is no such thing as a "bogus" patent. Decisions by the Patent Office are like decisions by the Supreme Court or the Pope. If you've got a patent, you've got a patent, and no one can infringe on it for any reason.
That depends on how you define a bogus patent. I would call any patent based on erroneous claims to be a bogus patent. Legally binding, but bogus none-the-less. Do you think the patent office would grant a patent if they knew up front the claims were erroneous? I wouldn't think so. However, I do find it surprising how little proof seems to be required. ICT isn't the only patent that makes claims without providing any proof. The VPP patent claims that the downward force at the rear axle is highest when the rate of chainstay lengthening is highest, but they don't provide any proof of that claim. The FSR patent is decidedly vague. It really only says something along the lines of: "If you build the linkage like this and put the pivots here, it will pedal and brake real good.". Not much more to it than that really. I guess I'm surprised that more proof of these type of claims isn't required to obtain a patent, but apparently it's not. You are right though, the ICT patent has been granted and is therefore legally binding. However, if I felt that ICT was erroneous, I would be somewhat annoyed if a bike that I bought came with an ICT sticker on it. But, as long as it's not laser etched, then I guess there's no harm done.
Steve from JH said:
Are you aware of how close the current Truth and the Nitrous are as far as ICT theory goes? The only real differences are less travel and a falling rate for the Nitrous. The Truth has a flat rate. The Nitrous would also seem to be suited for a smaller rider (I'm thinking height of center of gravity rather than weight).
No, not really. I haven't paid much attention, because I don't put much stock in ICT theory. I think that there are so many other things that have so much more impact on the way the bike rides (for me), that I wouldn't give it any consideration at all if I were choosing between Turner, Titus, Ellsworth, Ventana, etc. Plus, it doesn't claim to do what I want my bike to do anyway.
However, it does appears that the Nitrous is very similar. The Flux and 5-Spot less so. However, I wouldn't conclude that DT is an advocate of ICT theory simply because his bikes have become ICT compliant. I also wouldn't conclude that ICT theory is correct, simply because ICT bikes perform very well.
Steve from JH said:
What does "Tullebukk" mean?
It's a Norwegian word. I'm not sure of the exact translation, but it means something like "guy who kids around" or "person who jokes around" or something like that. My nephew started calling me Tullebukk, and since it was always available as screen name, I started using it. However, when I started getting answers in Norwegian, and since I don't know exactly what it means, I decided to change it. But, I don't really like "Backmarker" either, so...
