1 - 5 of 5 Posts
Hi everyone, I bought a 2nd hand bike recently with a Rockshox SID Race fork. It should be the 2009 or later version. The fork has been pumped to the pressure matching my weight, 160 psi for 90+kg. Its an 80mm fork which can be converted to 100mm but I don't think its been converted.
One of the issues I'm facing is that before I even ride the bike, the fork seems to have already sagged. There are sag indicators printed on the stanchion and it hovers around the 20% mark for the 80mm side, as shown in the picture below. I've also attached a picture of a fork that has the full indicator shown.
My fork:
Taken from the Internet:
I'm just wondering, is there anything wrong with my fork? Once I ride the bike it sags even more, leaving not much travel.
I've got a whole lot of other issues regarding this fork, especially setting it up for riding, and I've looked through a couple of websites but still not quite getting it. But I guess I'll just start off with this first. Thanks for the help guys. :)
Did you pump both air chambers ("positive" on top of the fork, "negative" at the bottom) higher to match your weight, or just the air chamber on top?
Discussion Starter · #4 ·
retro83 said:
Empty both chambers, pump the positive up then the negative. This should reset the piston position
Thanks man, I bought myself a Wrench Force fork pump and followed your instructions, the stanchion extended back to its original length.
Right now the indicator is at 100mm 0%, does this mean that the travel of my fork has already been converted from 80mm to 100mm? The previous owner did not tell me much.
yep
1 - 5 of 5 Posts
