I acutally in certain circumstances have picked forks that do this. I have never had my KM fork fo that. The 31.8mm upper of the fork is way stiff. I have had a stock Monocog fork exhibit this characteristic. I found that fork to be pretty comfy. I purchased a Flight Monocog fork for the reason that it would be stiffer with a bigger rotor/stronger disc brake combo. It rides pretty similarly to the KM with a touch more flex which is just about right. I would be interested to ride a Vicious, various Waltworks, and Badger forks I have seen in the recent past. Some of those use very small (28.6-ish mm or less) at the top of the Unicrown/Lug.
Also depending on the headset you might get some of that feeling as well. I used to swear by Chris King headsets, but the basic split ring designs offered from Cane Creek take care of any possible movement out of the headset. I'm not hating on King, it's just the top cap is machined aluminum and the bearing race is steel. Unless they were machined from the same block I just can't imagine it being a 100% perfect fit. The King definitely allows some movement/rocking that could be interpretted as a loose headset. Especially with a rigid fork. Not a problem with some squish under it as there is a lot of other areas of movement/ dampening to keep it in check.
