tell them to repair it under warranty
and skip the service you'll do that part yourself
What the hell?Hello Jan,
Thank you for your e-mail. Please return the rear shock. We will forward it for a service/repair. Please be prepared that a regular service together with the warranty repair is on charges. Since we have only few cases of SR Suntour I don't know. Fox and RockShox usually charge about 160 € for a service depending on the age and state of the shock.
I have just gotten a follow up email from them.What is the service interval on your shock? If it is over that then this is a pretty common practice. I dont agree with it but it is how the bike industry works.
Not at all.Suntour will be the ones who determine if it's a warranty issue or not. If not, there will be a cost to repair it and the online shop seems to be making sure you understand this.
If they decide they want to replace seals without me explicitly telling them to do so, it's on them.They will replace the air can seals, unless you have already. That's a wear item, around here that's about $20-$30 for seals plus $30 for labor. Your only real option is to send it in, have them inspect it and if they charge you €40 for fresh air can seals (a wear item) you're good to go. Expect to pay shipping.
IF they want to charge you more, it's up to you. Either pay up and get the shock back in working order or don't. The TriAir should be a good shock, worth the money. Similar if not identical ti the DVO Topaz
OR fix it yourself https://tech.dvosuspension.com/wp-content/uploads/2018/01/topaz_fullservicev2.pdf
What kind of junk is at end of service life in ~500km?The shock might be puking oil because common wear parts such as o-rings or seals reached the end of their regular service lives, so they would not be covered under warranty.
I feel like the guy was talking out of his arse without really knowing anything.I am sorry if there was confusion about the shipping costs. We do not charge you any return and forward shipping costs with the claim. I just told you for comparison sake that 40 € would offset the costs of shipping and handling that we have, associated with the claims procedure. Nothing you should worry about.
I cannot guarantee that the repair is without additional cost. You own the shock for more than 1 year, and a rear shock is a highly exposed item with seals, lubricants and so on that wear or deteriorate with use and storage. That is why most suspension manufacturers recommend an annual service or service intervals based on riding hours. Regular service is essential for proper function. A due damper service is usually not part of the warranty. If you are not willing to cover the costs for a damper service, we cannot register the claim.
Hi,
in this case the costs depends on the defect itself.
But if the oil loss will be connected to a defect sealing or something we will cover the repair as warranty.
So at least we have to wait for the contact from Bike24 if the will send it to us or not.
The latest contact was beginning of this year.
So I can not tell you anything more as the shock isn’t and wasn’t at our workshop yet.
