So I picked up a set of these http://www.choppersus.com/store/product/612/Rim-Only-26-x-4-Black/.
You've never seen your Endo's looking so pillowy
That, and they look bada$$!
However, I'm wondering if anyone else is running these? The spoke holes are spaced rather w i d e l y apart across the rim width. This doesn't allow for much dishing, as the hub flanges are more or less, directly under their respective holes. So, I find the wheel to be sitting rather to the driveside, and I can't move it over. This causes slight aligment issues, and pretty bad chain rub on tire and rim in the granny until I'm about halfway down the cassette. I'd respace the hub towards non drive, but then the rotor gets affected. Thoughts?
I'm also realizing that the SC32 up front has jussst enough clearance for the rim, the tire is a smidge wider, and will likely rub the legs. I'm going to play with it a bit, but I may have to go backwards to the 3" rim instead. I'd run the rigid fork, but I ordered a Pink King 36 hole Maverick 24mm TA hub for these, so I'm kinda tied to keeping the fork in the min. Live, learn and measure more
Thoughts? Don't know how common these are, so I'll post pics if there's a curious crowd:thumbsup:
