4x4runner said:
For $99 I couldn't pass it up. Pulled the trigger on a 21 incher. (Smallest available). I am used to a 19 inch with 110 stem so ill probably go with a stubby stem on this one. Any suggestions on ss vs. Geared? Also fs vs rigid?
Top tubes are kind of short for their size so it may be fine without a stubby stem
PS-here is the geometry of those frames with a 100mm fork
-----------------------------------17-----------------19--------------21-------------23
Seat Tube (C-T)----------431.8 mm-----482.6 mm---533.4 mm---584.2 mm
Seat Tube (C-C)---------361.8 mm------412.6 mm--463.4 mm---514.2 mm
Effective Top Tube------580 mm--------605 mm------630 mm------650 mm
Actual Top Tube---------555.7 mm-----577.1 mm---601.9 mm---625 mm
Chainstay------------------455 mm-------455 mm------455 mm------455 mm
Head tube-----------------110mm---------115 mm------140 mm------155 mm
Bottom Bracket Drop--60 mm --------60 mm--------60 mm--------60 mm
Wheel Base--------------1066.9 mm---1092 mm----1117.7 mm--1138 mm
Head Angle---------------71 deg----------71 deg--------71 deg--------71 deg
Seat Angle----------------72.5 deg-------72.5 deg-----72.5 deg-----72.5 deg
