1 - 5 of 5 Posts
I need help fitting my DEORE's to my SC Super 8. The disk slot on the caliper doesnt line up with the disk. The caliper is about 16mm out of line( to the outside). IS mounts
Meh.
Loosen the bolts that attach the caliper to the adaptor. You may need to use spacers, but 16 mm sounds excessive. Make sure you're using the correct adaptor. Pictures would help us to diagnose the problem. If you're really stumped, bring it to the shop.
1 - 5 of 5 Posts
