1 - 3 of 3 Posts
Short-Change-Hero
I think most all SR Suntour forks are internally travel adjustable. My Auron RC2 has "tokens" in the spring that you remove/add to adjust the travel. Mine goes from 130mm to 150mm with said tokens. Stupid easy to change and literally a 15min job at max.
The LO-R damper is the basic damper with only preset HSC adjustments. However, down the road you should be able to purchase the PCS RC2 damper and drop that in real easily. That is what I did with my Auron, purchased through the trade-in program then a year later upgraded the damper. The PCS RC2 damper has been incredible.
1 - 3 of 3 Posts
