I have been interested in stiffening up my swingarm and have read the posts on converting quick release hubs to 10mm thru-bolts. After considering a bunch of different wheel builds that offered a 10mm convertible hub (Hope, Stan's, Hadley, etc), I settled on Sun Ringle Black Flag Pro's. Sun Ringle describes the rear hub as being 12mm compatible, so at first I didn't think it would work with standard 10mm dropouts. But, after emails were sent to Sun Ringle they told me part 281-25122-Bolt is a step down bolt on axle that works with the 12mm center of the hub, but "steps down" to 10mm at the dropout. This also works with the Charger Pro wheels too. I asked my LBS to call Sun Ringle and order the kit.
With the kit, you get the step down axle, new hub end caps, and bolts. Of course, there are no instructions.
The disc brake side is a press fit, you wiggle the qr cap loose and replace it with the 12mm end cap.
The drive side is threaded on. I used a 5mm allen wrench.
With the 12mm end caps installed, the step-down axle just slides in. Then you align it with the drop outs and bolt it on. Pretty simple. I hope it stiffens things up this upcoming riding season.
