1 - 9 of 9 Posts
Hello everyone, I recently purchased a new frame, and I am in the process of swapping parts over to it. However, I just found out that the headtube is longer, so my steerer tube is barely long enough. As it is I can fit a CK headset and Thomson stem with no spacers and the steerer tube is just barely long enough. In fact, I would feel better if I had another milimeter or two. At any rate, I need more rise than the Thomson stem offers. Normally when I want a high rise stem I use the Salsa MotoAce, but it has a massive stack height. I know FSA has low stack height stems, but they only come in low rise. I am looking for something like 40 degree rise +/-. Any help would be greatly appreciated. Thanks!
Discussion Starter · #4 ·
Hmm, well this is a Vicious Cycles rigid fork, so the steerer tube is not replaceable. I'll definitely check out the Dangerboy stems. They may be a bit short for my needs, but they're definitely something to keep in mind. Thanks!
As long as the crown to axle height is ok and deosn't lower the front end too much, you could do what I did. I recently got a surly 1x1 fork which lowered the front of my bike (and my handlebar) about 1". So I switched to a 10 degree rise stem and a 2" riser bar. Feels great now.
Premium Member
I second the Dimension stem.
You could also look at the Cane Creek headsets which generally have a lower stack height than the CK.
Discussion Starter · #9 ·
Perfect! I saw the Dimension stems elsewhere, but I didn't know the stack height. I am going to swap the CK headset for the Cane Creek S2 on my other bike and purchase a Dimension stem. After I sell the Thomson stem I may even end up making a little money. Awesome, thanks everyone for your help. :thumbsup:
1 - 9 of 9 Posts
