1 - 16 of 16 Posts
Shread Ready
Now that summer is here and the heat is on I wanted to get some suggestions for trails that have shade and slightly lower temperatures. Don't get me wrong I love trails like Mt Falcon but a lot of front range stuff gets pretty gruesomely hot during the summer. I'm hoping to get some ideas for trails that are relitively close to the front range. I also wouldn't mind other trail suggestions that are a little more high-country this side of the Eisenhower tunnel.
One of the trials I like that provides a good amount of shade is Elk Meadows. I'm also thinking Heil Ranch might be pretty well shaded. Appreciated any suggestions for cooler rides.
ride
I like the riding west of the Peak to Peak up North. West Mag is good on a hot day, so is all the Sourdough/SSV riding. Jeep roads above Caribou aren't shaded but are really high elevation.
Despite the shade at Heil, it's still low elevation and can get pretty warm on a hot day.
"Oldfart from Wayback"
It's a long drive for some short rides
But the Poudre "Gulch" trails W of Ft. Collins are nice. All three are about 8 miles RT, all are tucked down in steep "Gulches" that help keep the sun off, and all feature MANY stream crossings. Ride Hewlett's first in the morning, there is a long steep meadow section towards the top that has no shade but if you ride back down it at the normal 35-40 mph it will be cool. Then do Youngs , a huge splash-fest w/ about 70 steam crossings in the RT. Then drive up the canyon some more to Dadds a lot higher ride that can be extended up some FS roads to near timberline.
Bring a change of dry socks at the least. :D
just go up to all trails above ~9k. even if there's no clouds its still 65-70 degrees. i still carry around a polycap shirt because some of the descents get cold (particularly after a sweaty climb).
Shread Ready
Discussion Starter · #6 ·
ignazjr, where are those trails? Are those up in CS?
nOOby, Where at in Golden Gate? I. Don't think I've road over there. I've rode Centennial ConeTrail but that is like a 12mile loop that doesn't have much shade. Thanks for the suggestion.
onbelaydave, I'll have to check out that ride when I go up north. Sounds pretty fun for a hot day. Might be a little much with 70! stream crossings? Wow! How many miles is that? You mentioned driving also during the ride? Hall Ranch is about as far North as I've road. That's a hot one also.
nomit, Good point and I'm sure I'll get quite a few 9K + rides in. I just want to find all the closest rides in my area that are cooler.
I went and rode Apex by Heritage Square for the first time today and it was quite fun and close. Even though it was a cloudy day it was about 85+ but I didn't get very hot. I think that ride would be one of the cooler Front Range rides when the suns out. I took the suggested route on Singletracks.com. It came to 8.6 miles and their are quite a few trees on that ride. Especially in the Enchanted Forest area! That was an excellent area on the ride!
ride
Hey Thrasher, check the map for riding west of the Peak to Peak starting at Nederland and going all the way north to Raymond/Allenspark. Sounds like it might be a bit further drive from where you're coming from but definitely worth it. LOTS of riding.
bacon! bacon! bacon!
Thrasher said:
<snip>
It's soooooooo much better as a shuttle. :cool:
what nice teeth you have
Kelly Flats and Seven Mile Creek are fun ones too. They are up the Poudre a ways. Beaver meadows in Red feathers lakes has some decent elevation too and is a bit cooler with some very very cold stream crossings.
tiny rider
Lair of the Bear is nicely shaded. It's pretty low, though.
Much of GGSP is treed, though Elk has some long stretches of buff single-track through meadows you'll just have to suffer through ;) The double-track grind up Burro isn't the best for shade either, I suppose. Still, it's a great place to ride.
I spent some time recently toodling around Aldefer/Three Sisters and that's fairly close and well treed with a good mix of trails to make a short or longer ride. Catch the connector to Dedisse too :)
Shread Ready
Discussion Starter · #12 ·
I just did this ride yesterday. It was excellent for a hotter day! I hit it at about 4pm while it was around 88 degrees. Much of it was shaded and not very strenuous for a 12mile ride.
I remember hitting the 3 Aldefer/Three Sisters last year but it seemed like a short ride at about 6-7 miles the route I took. Might be good for a hot day. Today I'm chilling in my AC apartment hung over from Red Rocks show. Keep the suggestions coming-esp for closer front range ride.
friend of Apex
You missed quite a bit of the trails. I've logged 15 - 20 and not hit the same trail twice (at least in the same direction)
Hit Bergen, too
Wurd
Looks cool outside now, less hot tomorrow
1 - 16 of 16 Posts
