It seems that I have developed play in my main pivot between the actual frame material and the pivot bolt sleeve. New bushings did not solve the problem. The sleeve doesn't sit tight enough so the main pivot moves up and down, then wears out my busings within a few rides. Fisher says it is because LBS didn't use green loctite over the many bushing replacements. Fisher says this is not a warranty item and that the LBS should get me a new Front triangle at their cost. LBS said, ya right! Anyone know of a fix for the sleeve/frame fit/tolerance? Anyone else experience this?
