Sub 36 lb FS emtb!?
The weight weenie wand was waved over ebikes and this is the result, a $10000+ 15.9 kg (35 lb) 120mm FS emtb:
It has a Fazua motor (60 Nm torque, 4.9 kg system weight), so it's not in the same league as the other 250W rated motors (weighing over 1 kg more), but that's actually what some people want (e.g. Mike Ferrentino). They figure the 255 Wh battery is good enough for typical ride lengths, considering the improved efficiency and how freely the bike can be pedaled with the motor off. In typical weight weenie fashion, there's a weight limit of 90 kg (200 lbs).
https://ebike-mtb.com/bulls-emtb-neuheiten-2019/ (German language source, so bring your own translator)
