So. I discovered that a 29x2.3 DHR2 on a Boost hub fits in the rear of the 2016+ Balance with plenty of side clearance. I started crunching numbers:
You'd have to prevent the shock from reaching the last 11mm of travel, reducing the total rear wheel travel to 135mm.
You'd have to run a 140mm 29er fork with a zero-stack headset, which would put the head angle at 65.5 degrees.
Bottom bracket height would go from 343mm to 363mm.
For all that work you may as well just buy a Riot, but if any crazy fool wants to try building a mid-travel 29er with 420mm chainstays, there's your recipe.
