I've got a stock 13' Stumpy FSR Comp, I'm looking at a Carbon bar upgrade to smooth out chatter for those longer rides. Enve seems to be a well liked brand of carbon components so I am looking at their RSR (riser) bar. I'm open to other suggestions, but this is my first choice right now. Here's my question, how much will I notice the difference in the "fit" of these bars vs the stock as some of the numbers are slightly different. I currently like my set up, fit wise, so I don't want to monkey with it too much. It appears they should feel pretty similar to me, but not sure, hence the question.
Specs: Specialized Bar || Enve Bar
Width: 720mm || 740mm (I'm assuming I could cut these down if needed)
Rise: 10mm || 23mm
Sweep 10-degree back / 6-degree up || 9-degree back / not sure? Is this the TIP measurement listed as 5-degrees?
Stumpy Specs: Specialized Bicycle Components
Enve Specs: ENVE Carbon Riser Bar
On a side note, I already picked up some XT Brakes to replace the freaking Avids which I'll install at the same time as the new bar, can't wait.
Thanks in advance for your advice!
Rise: 10mm || 23mm
