1 - 4 of 4 Posts
· Registered
You can remove the quick release lever and simply fasten a nut and bolt through the existing clamp. It's what I used to do on my old Marin Mount Vision and it held the seatpost securely in place.
The allen bolt and nut that comes with a cheap skewer set like this one will work.:)
http://www.jejamescycles.co.uk/kf-allen-key-item41431.html
The seatpost clamp on the 2011 FSR Expert Carbon is supposed to be 36.9mm diameter.
You can get 36.4mm diameter single bolt seatpost clamps such as the Hope ones.
http://www.hopetech.com/page.aspx?itemid=SPG70&tab=specification
You could modify one of them to fit your frame by using sandpaper to increase the internal diameter until it can be pushed into place.:)
1 - 4 of 4 Posts
