1 - 4 of 4 Posts
· Registered
Does anyone know how to remove those bearing caps just under the screws covering the bearings on stumpjumper evo and stumpjumper suspension pivots?
Reason is i wont to seal the all the pivot bearings with grease
· Elitest thrill junkie
You want to what? If you are going to re-pack bearings, you need to pull them out of the frame, with a bearing-puller, to avoid damaging the bearing (which still happens sometimes anyway). If the bearing is gritty and rough, it's already dead and you need to order new ones. You can get a little more life out of it by repacking at that point, but really just until the new ones come in, the tolerances have already been ground down and it's on it's last legs. To re-pack bearings, you have to pry off the dust seals and pass new grease through to purge the old grease out. This is a little delicate to get the seal off, with a dentist's pick or similar pry tool and then packing involves a ring of grease and pushing it against a surface like your hand, to purge to the other side. This can be good for some new bearings to keep water out, since they tend to come with much less grease for high rotation applications (which bike pivots are not).
· Registered
Discussion Starter · #3 ·
sorry didnt make myself clear, dont want to do that now , but i heard it was a best practice to coat the seals outer side with grease which helps prevent crap getting passed the bearing seals,
something new, with new stumpy the actually have a metal cap retainer that the screw goes thru sort of looks like the letter T only upside down the screw goes thru the long part which goes thru the bearing i want to get under the cap and coat the outer seal with grease because the bike is a couple of months old
1 - 4 of 4 Posts
