hey everyone, i've got a quick question for all you stumpjumper and enduro and fsrxc owners. How often do you need to replace the little bushing in the lower end of your shock? I've been told be the lbs that the fsr design puts lots of wear on these bushings so they need replacing relatively often, but after getting mine replaced last week, i've been on TWO rides (of maybe an hour and a half each) and already the alloy reducers can be turned (albeit with some effort) by hand! the guys at the lbs had said that the alloy reducers are a press fit into the bushing (they push them in with a bench vice). do they only need to be replaced when you can feel slop in the suspension or should they be done before that point?? hope you guys can help me out!
cheers
cheers
