I found snow/ice bike nirvana! I was tempted to use sheet metal screws or hex screws to stud my endos, but decided to check with a local auto tire dealership. I told him I was looking for studs and he came out with boxes of different sized studs. I chose the 11mm stud with aluminum carrier and tungsten tip. They sell for $60 for a box of 1000. He sold me 400 for $20. I drilled a full thickness 1/8" hole in the center of each lateral lug (total of 100), applied some epoxy to the stud and pushed it through (inside to outside of tire). My thumb was pretty sore but it didn't take more than 1 hour. The studs weigh 1.5g each (150g total for you MIT grads). The base of the studs sit flush with the inside of the tire so I don't think I'll need a protective strip. So far I have only done the front tire and it works great! I'm tempted to do a 2nd row of studs and also do the rear tire, but it seems to be doing well so far. I have done several rides, including pavement, and the studs have not dislodged, and I have had no flats.
