1 - 3 of 3 Posts
· Misfit Psycles
Olde LX or XT square taper bb. Specialized Rockhopper vintage '90? Owner claims the BB was removed 5 years ago but I doubt it...this motha is stuck. Using Park BBT-2.
Ideas?
The BB is toast and I just can't budge the bloody cups...
· Old man on a bike
Use a longer lever arm, put a piece of pipe or an old seatpost or something similar over the end of your wrench to get you more leverage. Be sure to loosen the drive side cup clockwise...
· Registered
Ideas?
soak it with liquid wrench (or similar lube), from the seattube... might need to repeat a few days in a row. maybe even heat up a bit with a propane torch to help the BB expand a bit.
more leverage is always good, BB tool in vise using bike as leverage to twist, or a cheater pipe.
depending on the type of BB tool you've got, you may be able to use a QR to help hold it onto the BB, to avoid stripping tool &/or BB cups.
there's some more good info, check out the search function... I tink on either tooltime or drivetrain.
good luck! I had to do the above, with multiple times heating/cooling cycles and wd-40 type of stuff, then using a good length of pipe on the BB tool for leverage.
1 - 3 of 3 Posts
