1 - 3 of 3 Posts
First convrted using a magic gear, but...the chain was too tight for my liking.
Decided to put a tensioner on, my gearing is 40 / 21 but the issue I have now is even on max I cannot tension the chain up enough now with a extra link in, so I removed the one bolt of the tensioner to enable me to push the tensioner further down to tension the chain. It works, but...after a couple of rides the tensioner shifter a little up. It's only being held by one bolt now and the chain is pushing againts it up the whole time. Anyone have a idea how I can fix it? Without changing my gearing?
I had a similar issue with the STS tensioner. To be able to use it in the push up mode I had to adjust my gearing slightly. I think I ended up going one tooth bigger on the front.
Other option is use a half link. I tried this as well but didn't really like using it as the half link I had didn't fit well with my chain.
Having said all that, I really liked the tensioner once I got it dialed in. Never gave me any issues.
What nomad9 said, either change your gearing, or add a half link.
The only issue is, if you had a half link using the proper parts, it won't fit in the groove of the STS' roller, so you either have to modify the roller (pretty easy to do), or add a new roller with a wider groove.
1 - 3 of 3 Posts
