Hi - hoping to for advice for a new rim on a heavy cargo bike. I typically run 4.8" tires so would default to 80mm rims (but open to other opinions). easy tubeless is a big plus. Non-offset build, 32h. (I would go 36h, but near zero hub compatibility
What are my best options for bomber rims?
I have run Mulefut 80sl's for a while, but with the new v2 the holes are HUGE (seems like some folks are having issues with tubeless builds; also the single mtbr thread mentions the rim vent holes are worse on the v2). I've had no problems but do try to baby them a bit. The MOBD symmetrical seem pretty similar to the mulefut's. Weinmann makes a _very_ heavy double wall.
Thoughts on the above? Any other options I should be considering that are notably stronger?
