Also, Stan's braking power seems to be quite a bit less than my old Magura steel rotors.
Thoughts/opinions/advice anyone??
This is already a replacement rotor.barrows said:I would contact Stan about this. Sounds to me like he owes you another rotor. Maybe the rotor is expanding when it heats up? I would expect that Al rotors would expand more than steel.
And it scrapes when it's cold......as soon as it is installed.barrows said:I would contact Stan about this. Sounds to me like he owes you another rotor. Maybe the rotor is expanding when it heats up? I would expect that Al rotors would expand more than steel.
I place it on a very flat surface. It appears to be completely flat.B R H said:I bet it has a slight cup shape to it. This would be virtually impossible to see with the rotor mounted. Remove it and place it on a very flat surface. If it is cupped, the outside edge won't touch all the way around on one side.
Stan said he would take them back if I'm not satisfied. Cudos to Stan for sure.mtbbiker1 said:CMV, if I am reading this right it sounds like the rotor is too large of a diameter. If it is rubbing the top portion of the caliper rotor clearance hole when mounted, this would have to be the case.
I would suggest: loosen the caliper bolts (al or ti hopefully), hold up on the caliper while snugging them back up. If the interference is minor, the clearance holes in the frame may have enough slack to help you out. If not, send em' back.
Please see my original post:DeeEight said:The rotor isn't actually perfectly round, and if scrapes constantly its because it wasn't cut to the correct diameter either. Nothing like poor quality control from stan.
cmv96 said:I've had a new Stan's aluminum coated rotor on my front Magura disc brake now for about 2 weeks. I just put a new Stan's rotor on my rear wheel. However, the rear rotor is scraping on the inside top edge of the caliper. You can see scrape marks developing on the outside edge of the rotor. However, when I hold my finger just above the outside edge of the rotor carefully bracing my finger against the top of the caliper, it appears that the outside edge is perfectly round and true. How can this be? I'm stumped. When I put my original Magura rotor back on, the scraping noise goes away. There is no scraping on the front with my Stan's rotor. AND, when placed side by side, the new rotor appears to be exactly the same diameter as the Magura rotor. But then why doesn't my Magura rotor scrape??
Nothing like talking out your @ss. The rotors are laser cut, not likely the cut diameter is a problem.DeeEight said:The rotor isn't actually perfectly round, and if scrapes constantly its because it wasn't cut to the correct diameter either. Nothing like poor quality control from stan.
Stan and I both hypothesized that there might have been a coating build up on the periphery, however, I had the same problem on all three of the Stan's rotors I tried! But the brake works perfectly with the Magura discs bolted in.Mike B. said:Nothing like talking out your @ss. The rotors are laser cut, not likely the cut diameter is a problem.
By the way, I run the new rotors with Martas and don't have any problems. I think Stan's offer to take the rotors back is more than fair. It's possible there is a coating build up on the periphery.
Yeah, tried that Redrock. Same problem. Dang puzzling.redrock_z71 said:I'm sure you may have tried this already.... but..... have you tried putting the good front one on the back yet? It would be curious to see what happens.
