1 - 2 of 2 Posts
Hey I was wondering from the post below about the Marzocchi lube issues if these lubes would be recommended for use with my 2003 SID Team. I've heard something about not using certain lubes with open bath systems but I'm really not sure. I had just sent the fork back to rock shox for them to service it and when i got it back it had some kind of thick lube/grease on the stanchions which seemed to work great until it all went away. For the time being i'm using Tri-Flow *Teflon included lube which i spray directly on the stanchions and compress to work it in. Is this ok or is there a better solution? Thanks
otb club member
Check out this thread:
You've probably already seen this thread. It addresses this exact issue:
http://forums.mtbr.com/showthread.php?t=35794
-Chris
http://www.enduroforkseals.com/
1 - 2 of 2 Posts
