1 - 5 of 5 Posts
I have used a XT rear hub,an LX rear hub and a Parallax hub with sticky cassettes. These stick when I freewheel or coast or pedal backwards.I was able to fix one with a shot of WB40 after removing the HG cassette but that may not last. Is this common with Shimano hubs and can these be fixed?
Mantis, Paramount, Campy
Pretty Common In My Experience
Although I haven't used many Shimano hubs or freehubs.
LX, DX, XT, XTR, DA, Ultegra...had it happen with all of them.
This is normal for shimano freehubs. They can be overhauled, there are 50 1/8" bearings inside plus the 2 pawls. WD-40 is a quick fix, and is fine to flush the freehub body but a light oil is better.
moonter said:
I'm aware of these but have never used one.
http://harriscyclery.net/site/itemdetails.cfm?ID=559
HTH
Injecting grease into your free hub body is not a good idea since it is far to high a viscosity. I would flush with oil, an automotive synthetic like a 0w - whatever would be good. grease will prevent the pawls from swinging out and engaging the ramps on the inside of the freehub body. The only time i use grease in a freehub or freewheel is when i am overhauling them. I will use grease to help stick the multitude of 1/8" bearings to the freehub carrier and hold them in position.
When adding oil to the freehub body I will go with something as thin as triflow if the rider is a trials rider or thicker if the rider is riding year round and exposing the freehub to alot of moisture,since a thicker oil will be less likely to be washed away or displaced by water.
Try this link, it has a picture of the tool required to overhaul a freehub
http://www.sheldonbrown.com/k7.html#bodyservice
1 - 5 of 5 Posts
