1 - 3 of 3 Posts
"El Whatever"
Jwind said:
My rear Hayes brake lever sticks a bit after pulling... should I lube it? If so, any suggestions on lube?
I don't know on Hayes... maybe a bleed is in order too, check for sticky pistons, etc.
But if you may use something to lube your seals, maybe you'd use what's inside the brake. The same break fluid.
1 - 3 of 3 Posts
