I'm trying to replace the handle bars on my scooter (2006 Honda Ruckus) with lower mtb ones but the handlebars and stem are one integrated piece so I need to replace both. This is a bit of an issue cuz my steerer tube is only 15/16 of an inch.
I'm trying to find a stem that's not ridiculously long and is made for a 1" steerer tube. If I use a 1 1/8 stem like most mtb stems then that's about 28.5mm diameter which is pretty far off. I know mtn bikes used to use 1" steerers which is a lot closer at 25.4mm. If I can get one of these then I could either shim it or just clamp it down hard. If I have to go with 1 1/8 I guess I could shim it that much but I'm not stoked about doing that...I'd like a pretty generic stem that's black and the shorter it is the better....nothing longer than 75mm cuz the stocker setup is 0mm...Any idea's?
