Not that it matters, but your numbers seemed way off to me. I couldn't believe a 7:1 ratio of comparable strengths, so I thought I check with a
reference. Be sure to scroll all the way down to the disclaimer at the bottom of the page.
Sure enough the difference is much smaller. The actual heat treat, and other considerations will make for some variation, but these are better numbers for comparison purposes.
Don't go crazy trying to be a metalurgist, since material strength considerations were factored into the design by the makers, so stems of either material will do the job. Buy the right clamp, length and rise, and the stem, not being too bright, won't care what kind of bike it's on.
As a rule MTB stems will be made stronger (though possibly heavier) to allow for the greater twisting forces longer handlebars make possible, though even that assumption is open to challenge. In any case stem breakage (in alloy stems) isn't that a common an occurance.
